Normal Topic Find tablenode using ID (Read 1591 times)
newbieDraw
Feb 15th, 2012 at 10:29am
I am developing an app to design bayesian networks using tablenodes. Each table node holds 2 values in 2 rows. Is there a method I can use to access the table node (like FindNodebyID method). I need to access all the table nodes in the diagram so I can analyze the network structure. What is a suggested way to accomplish this?
Re: Find tablenode using ID
Reply #1 - Feb 15th, 2012 at 12:03pm
This will loop over all tables:
foreach (DiagramNode node in diagram.Nodes)
      TableNode table = node as TableNode;
      if (table == null)
            continue;
      // process table
Or if you need to access specific table by id, you will have to cast the FindNodeById result:
TableNode table = (TableNode)diagram.FindNodeById(...);
newbieDraw
Reply #2 - Feb 16th, 2012 at 6:31am
Thanks, Stoyo. I have another query regarding the same project that I have posted as a separate thread. Please have a look at that too.
