Normal Topic How to make dockable for node to loke as background (Read 1270 times)
Hamdy Ghanem
Feb 16th, 2012 at 8:37am
Hi there
I need to but a node as background (locked) it has an image
how to make it like dockable so if i resize the owner control of diagram view stretched to fill all space
Re: How to make dockable for node to loke as background
Reply #1 - Feb 16th, 2012 at 2:39pm
If you need to show that image in the part of the diagram that's visible in the view regardless of scroll position, it is best to do that from the DrawBackground event handler:
private Image backImage = Bitmap.FromFile(@"...");
private void diagram_DrawBackground(object sender, DiagramEventArgs e)
	RectangleF viewport = diagramView.ClientToDoc(diagramView.ClientRectangle);
	Utilities.DrawImage(e.Graphics, backImage, viewport, ImageAlign.Fit);
If for some reason you must use a node, handle the ScrollChanged and ZoomChanged events and set the node's Bounds to the viewport rectangle as calculated above.
