Normal Topic Does the diagram support Arabic language? (Read 4314 times)
Homam
Feb 27th, 2012 at 12:34pm
Seems that the diagram doesn't support Arabic Language, right?
It renders the Arabic text from left to right instead of right to left, with the knowledge that it renders every work correctly.
In the attached a snapshot.. Any suggestion?
Re: Does the diagram support Arabic language?
Reply #1 - Feb 27th, 2012 at 12:42pm
Have you tried setting the DirectionRightToLeft bit in node.TextFormat.FormatFlags?
Homam
Reply #2 - Oct 1st, 2012 at 7:48am
Yes, I have and it's the same. Any suggestion?
Reply #3 - Oct 2nd, 2012 at 6:15am
I think it's shown in the correct order after setting the DirectionRightToLeft flag:
Homam
Reply #4 - Oct 3rd, 2012 at 12:16pm
That seems to be true only in some kind of nodes. In the attached, the same string has been written to a ShapeNode and a ContainerNode. Only the ContainerNode is showing it correctly.
Please check it.
Reply #5 - Oct 4th, 2012 at 6:19am
I can see the sentence appears reversed with the EnableStyledText property of ShapeNodes enabled, so try setting it to false. I suppose we have never implemented right-to-left support in our text formatting algorithm used with styled text. With that feature disabled, the nodes draw text using the GDI+ DrawString methods which should work correctly.
Homam
Reply #6 - Oct 4th, 2012 at 7:51am
I haven't changed it. It's already false for both the diagram and the nodes - I checked them both.
Reply #7 - Oct 4th, 2012 at 8:40am
Try disabling the PolygonalTextLayout property, it runs the same text layout algorithm of ours. If it still doesn't work, check if there isn't some code changing the StringFormat.FormatFlags value later on.
Homam
Reply #8 - Oct 8th, 2012 at 9:24am
Disabling PolygonalTextLayout solved the problem.
Thank you Smiley
