Normal Topic Keyboard behavior (Read 2854 times)
JR
Keyboard behavior
Feb 28th, 2012 at 10:27am
I have a question about keyboard events and keyboard behavior.
I have a diagram.
I can move in the document with the arrows keys, scrollbars and mouse wheel.
I have put the following code
Ocx_Flowchart.KbdActive (true)
Ocx_Flowchart.KbdBehavior (0)	//kbScrollView
I don't want that the DEL key deletes an item.
How can I forbid this ? I don't need also cut/copy/paste actions.
Regards
Re: Keyboard behavior
Reply #1 - Feb 28th, 2012 at 11:54am
You will have to disable KbdActive and scroll the diagram yourself in response to the KeyDown event:
Private Sub fcx_KeyDown(ByVal KeyCode As Long, ByVal Shift As Long)
    Dim vkLeft, vkUp, vkRight, vkDown As Integer
    vkLeft = &H25
    vkUp = &H26
    vkRight = &H27
    vkDown = &H28
    If KeyCode = vkLeft Then fcx.ScrollX = fcx.ScrollX - fcx.ScrollRate
    If KeyCode = vkRight Then fcx.ScrollX = fcx.ScrollX + fcx.ScrollRate
    If KeyCode = vkUp Then fcx.ScrollY = fcx.ScrollY - fcx.ScrollRate
    If KeyCode = vkDown Then fcx.ScrollY = fcx.ScrollY + fcx.ScrollRate
End Sub
JR
Reply #2 - Feb 28th, 2012 at 1:14pm
Thank you.
It works
