Normal Topic Mouse wheel question (Read 4944 times)
JR
Feb 27th, 2012 at 3:55pm
I have a little problem.
My diagram have scrollbars.
I want to scroll the diagram with the mouse wheel but it does not work.
How can I do this ? Is there a property to set ?
Regards
Re: Mouse wheel question
Reply #1 - Feb 27th, 2012 at 3:58pm
Handle the MouseWheel event and add its delta argument to flowchart.ScrollY.
JR
Reply #2 - Feb 27th, 2012 at 4:23pm
Do you have an example because the result is amazing.
The language is Powerbuilder. It seems that we go out of the diagram.
Ocx_Flowchart.ScrollY = Ocx_Flowchart.ScrollY - delta
Regards
Reply #3 - Feb 27th, 2012 at 5:30pm
Private Sub fcx_MouseWheel(ByVal delta As Integer, ByVal keys As Integer, ByVal docX As Long, ByVal docY As Long)
    fcx.ScrollY = fcx.ScrollY - delta / 20
    If fcx.ScrollY < fcx.DocTop Then fcx.ScrollY = fcx.DocTop
End Sub
JR
Reply #4 - Feb 28th, 2012 at 8:42am
Great
