Normal Topic How to set different shapenode with custom anchorpattern from javascript (Read 1804 times)
ncepu
Mar 5th, 2012 at 6:37am
How can I use javascript to set different shapenode with custom anchorpattern but not predefined anchorpattern.
Thanks.
Re: How to set different shapenode with custom anchorpattern from javascript
Reply #1 - Mar 5th, 2012 at 8:30am
If using JavaApplet mode, you can call ScriptHelper.createAnchorPattern() to get a new AnchorPattern instance. Then use ScriptHelper.createAnchorPoint(x, y) to create anchor points, and add them to the pattern via the AnchorPattern.getPoints().add() method.
ncepu
Reply #2 - Mar 5th, 2012 at 8:41am
Thank you very much!
