Normal Topic Changing appointment colors on the fly (Read 2527 times)
john6630
Mar 9th, 2012 at 5:08pm
Hi Meppy,
In my application I have production runs for various products scheduled throughout the week. So each run is an appointment to my calendar. When the user clicks on a run (appointment) I want to set the color of all other runs matching the item being produced to the same color. I save the run information in the app tag. I have tried the following placed inside calendar.ItemClick
theSelectedRunInfo = e.Item.Tag
theTargetItem = theSelectedRunInfo.ItemNumber
For Each app As Apointment In calendar.Schedule.Items
  theRunInfo = app.Tag
  if theRunInfo.ItemNumber = theTargetItem then
    app.Style.Brush = New MindFusion.Drawing.HatchBrush(....)
  end if
Next
(Note, I typed the above so it is pseudo code for what I am doing).
The problem is that when I run this, the selected item looses its selection and drag drop does not work (seems to be dragging but the selected item remains still).
Am I doing this correctly or is there a better way. In the end, I just want to color the other runs (appointments) but have the functionality of selection, drag/drop etc. unchanged for the selected item.
I hope this makes sense.
TIA,
John
john6630
Re: Changing appointment colors on the fly
Reply #1 - Mar 9th, 2012 at 5:36pm
Hi Meppy,
I discovered a bug in my program. I was resetting the calendar in another event that caused the problem. But I am interested if the above process is the best way to handle changing the colors on the fly?
TIA,
John
Reply #2 - Mar 11th, 2012 at 7:33am
Hi John,
Changing the item appearance through the item's Style (SelectedStyle, PointedStyle, and so on) is most appropriate.
