Normal Topic PdfExporter and accented characters (Read 3428 times)
AD2012
Mar 16th, 2012 at 7:44am
MindFusion.Diagramming for WinForms, Professional Edition
MindFusion.Diagramming.Export.Pdf.dll fileversion 5.3.3.27353
Visual Studio 2010, VB, .NET Framework 4
I'm using this code for exporting the diagram to a pdf file
            Dim loExporter As New PdfExporter
            loExporter.Export(Diagram1, lsFile)
Att2: print screen of diagram
Att1: pdf file as result of the export
Some accented characters are displayed as "?". Please how can I fix this?
Proc3082.pdf (Attachment deleted)
Re: PdfExporter and accented characters
Reply #1 - Mar 16th, 2012 at 7:58am
Try setting PdfExporter.AutoDetectEncoding to false and set PdfExporter.DefaultEncoding to the character encoding you'd like to use.
AD2012
Reply #2 - Mar 16th, 2012 at 8:10am
Stoyo wrote on Mar 16th, 2012 at 7:58am:
I'm getting this error:
'AutoDetectEncoding' is not a member of 'MindFusion.Diagramming.Export.PdfExporter'.
Probably my version of MindFusion.Diagramming is outdated.
Please confirm that your suggestion will fix the problem, I' ll check in the meanwhile the possibilty to upgrade.
Reply #3 - Mar 16th, 2012 at 8:59am
I don't have such characters on my keyboard, please copy some sample text here or attach a diagram file and I will test it with these settings. You could also check if you don't have a newer version in your download archive at http://clientsarea.eu/.
AD2012
Reply #4 - Mar 19th, 2012 at 7:36am
Stoyo wrote on Mar 16th, 2012 at 8:59am:
&é"'(§è!çà)-
^$ ù µ € ¨* % £ ?./+ ,;:= +=%£ [ ] ´`~
Latest version on download page = 5.5
« Last Edit: Mar 19th, 2012 at 8:58am by AD2012 »
Reply #5 - Mar 20th, 2012 at 7:50am
V5.5 exports all characters correctly from what I can see. This is a PDF exported from the 5.5 demo without changing anything in the export menu handler:
http://mindfusion.eu/_samples/accents_test.pdf
