Normal Topic Ruler Unit is not working (Read 2667 times)
Christoph_F
Mar 16th, 2012 at 9:45am
Dear Mindfusion support team,
it seems to me that the Ruler.Unit property is not working properly. If I change the unit to pixels or anything else I always get it in centimeters (I think).
Any ideas,
Christoph
Re: Ruler Unit is not working
Reply #1 - Mar 16th, 2012 at 1:04pm
It seems Unit wasn't implemented and the scales always displayed millimeters. On the PM page you can find an updated dll file that should fix this.
Christoph_F
Reply #2 - Mar 19th, 2012 at 6:36am
Hi Stoyan,
I just added the new zip files to project and the ruler is working now! Are these modifications based on the latest source. I just want to make sure that this does not lead to a dead-end on the code with respect to newer version.
Christoph
Reply #3 - Mar 19th, 2012 at 8:29am
Yes, this will be available in the next official release. In case you need the code to compile custom assemblies, you can find updated ruler.cs on the PM page.
