Normal Topic control bezier-style link direction in javascript (Read 2176 times)
hans
Mar 17th, 2012 at 8:43pm
using Jdiagram.jar I want to make the bezier-style links always start and end horizontal. Is there a way to do this ?
Can this be done with the link.controlpoints ?
Re: control bezier-style link direction in javascript
Reply #1 - Mar 19th, 2012 at 8:17am
If you add anchor points to the left and right sides of nodes and enable auto-routing, links should always start and end with horizontal segments. You could also ensure that by setting ControlPoints coordinates after links are created or modified.
