Normal Topic Node lock (Read 1595 times)
PDM.
Senior Member
Node lock
Mar 27th, 2012 at 11:37pm
I trying to lock nodes.
var nodestolock = form.Selection.Nodes.Clone();
foreach (DiagramNode node in nodestolock)
node.Locked = true;
Same code for unlock, just change:
node.Locked = false;
The problem is after lock the node, is impossble select again for unlock lol
What im doing wrong?
Cheesy
Re: Node lock
Reply #1 - Mar 28th, 2012 at 11:31am
Locked nodes cannot be selected. If you need to allow selection but prevent move and resize, set EnabledHandles to None.
