Normal Topic Anchor points labels (Read 1426 times)
danilom
Mar 29th, 2012 at 4:01pm
Hi Stoyan,
Is it possible to assign a label to the node anchor points?
The label should be visible near the anchor point.
Danilo
Re: Anchor points labels
Reply #1 - Mar 29th, 2012 at 5:31pm
Hi Danilo,
Out of the box you can only assign tooltips to anchor points. If you need to show permanent labels, you could use custom drawing or display them in attached nodes.
