Normal Topic How to hide a row of TableNode? (Read 3993 times)
CanadaProgrammer
Apr 1st, 2012 at 11:33pm
I try to hide a row of a TableNode. The Head property of row is true or false. To collapse and to expand a row is not what I need.
Thanks a lot.
Re: How to hide a row of TableNode?
Reply #1 - Apr 2nd, 2012 at 6:14am
There's no Visible property for rows, but you could set their Height to 0 as a work-around. The Bounds assignment forces links to update their positions after the row height is changed:
private void diagram_CellClicked(object sender, CellEventArgs e)
	// hide the clicked row
	e.Table.Rows[e.Row].Height = 0;
	e.Table.Bounds = e.Table.Bounds;
CanadaProgrammer
Reply #2 - Apr 2nd, 2012 at 2:43pm
then how to show a row again? thanks.
Reply #3 - Apr 2nd, 2012 at 4:45pm
If all rows are the same height, you could set table.Rows[n].Height = table.RowHeight. If rows can be of different heights, you will have to store the original row height somewhere, e.g. as a value of some cell's Tag.
CanadaProgrammer
Reply #4 - Apr 2nd, 2012 at 5:34pm
why need "e.Table.Bounds = e.Table.Bounds;", looks it does nothing
Reply #5 - Apr 2nd, 2012 at 6:01pm
It's a hack to redraw the table and update link positions, since the row.Height setter doesn't do that. If you are hiding rows before the table is drawn and has links connected to it, you don't need to reset Bounds.
CanadaProgrammer
Reply #6 - Apr 2nd, 2012 at 7:56pm
In my case, all links connect to table, no row, so is it necessary to set Bounds property?
Reply #7 - Apr 3rd, 2012 at 6:43am
Yes, if there aren't links connected to rows, you can skip that. You might still have to call Invalidate to redraw the table though.
