Normal Topic NodeCreating and NodeCreated events issue.. (Read 1694 times)
Czhao_pfs
Apr 5th, 2012 at 6:32am
I am working for StateSteet and I want FlowChart.Net to help build the new product of our company.
Currently I am evaluating the controls with the trial version, one (which is most likely the last) issue I have is the NodeCreating and NodeCreated events don't work as I expected.
When I create a shape node via code like:
WorkflowDiagram.Factory.CreateShapeNode(....
The events are not invoked.
Am I missing some settings?
Re: NodeCreating and NodeCreated events issue..
Reply #1 - Apr 5th, 2012 at 7:06am
Most events are raised only after users actions. If you need to run the same code for both users and program actions, you will have to move it to a common method called in both situations:
void HandleNodeCreated(node) {...}
void OnNodeCreate(sender, e) { HandleNodeCreated(e.Node); }
var node = diagram.Factory.CreateShapeNode(...);
HandleNodeCreated(node);
