Normal Topic End elements removed on empty elements (Read 7145 times)
Chris Austin
Apr 5th, 2012 at 9:59am
When viewing an empty element that has an end element in the source window, such as:
<element></element>
it is contracted and displayed as:
<element/>
Surely the source window should show the XML as it is in the source file?
Re: End elements removed on empty elements
Reply #1 - Apr 5th, 2012 at 10:34am
Thanks for your report. We are planning a revision for the XML Viewer tool. If it happens, many things will be improved (including the Source view).
