Normal Topic Re: Text Format (Read 1389 times)
Re: Text Format
Apr 11th, 2012 at 7:39am
If the text region is on the left of the shape, it should be enough to make the text right-aligned. This post shows how to use setTextFormat to align text:
http://mindfusion.eu/Forum/YaBB.pl?num=1333519776/2#2
Re: Text Format
Reply #1 - Apr 11th, 2012 at 10:29am
I can't see any problems with that. Are you sure you have copied the updated code or loaded the new shape library file?
