Normal Topic Expandable nodes (Read 2847 times)
Hunter
Expandable nodes
Apr 13th, 2012 at 7:08am
Hello. I have the following question.
I have the stadard ShapeNode and made them expandable. Is there any way to implement behavior: when node expands all other nodes which drawing on the the same place with children nodes are moving down or left (the same behavior as standard windows expander)?
Re: Expandable nodes
Reply #1 - Apr 13th, 2012 at 10:15am
You could run TreeLayout from the NodeExpanded and NodeCollapsed event handlers. This is shown in the DirTree sample project.
Hunter
Reply #2 - Apr 13th, 2012 at 10:33am
Thanks. It is practically what I need to do. But can I flip this tree on 90 degrees and make the diagram like in the attachment?
Reply #3 - Apr 13th, 2012 at 10:40am
Set TreeLayout.Type to Centered.
Hunter
Reply #4 - Apr 13th, 2012 at 10:42am
Thanks. I'll try to do.
