Normal Topic java-applet inside a shapenode (Read 2807 times)
hans
Apr 15th, 2012 at 10:56am
I have read somewhere that the contents of a shapenode can be a java-applet.
How would this be done ?
Re: java-applet inside a shapenode
Reply #1 - Apr 16th, 2012 at 6:32am
At this time there is control-hosting feature in our WPF, Windows Forms and ActiveX components, where you can use standard or custom controls as nodes. I'm afraid this is not supported in JDiagram yet, but as far as I know our developers are just implementing it in Java too.
Reply #2 - Apr 23rd, 2012 at 6:58am
With this version you should be able to use any object derived from java.awt.Component as a node, including JApplet instances:
http://mindfusion.eu/Forum/YaBB.pl?num=1334931471
Note that for applets you will also have to implement the AppletStub interface, and call the applet's setStub, init, start and stop methods.
