Normal Topic how to select shape by its ID in jscript (Read 3173 times)
hans
Apr 15th, 2012 at 11:05am
scripthelper.getShapes().get(int) works, but I want to reference by its ID (ie "roundedrect")
What is the syntax for that ?
Re: how to select shape by its ID in jscript
Reply #1 - Apr 16th, 2012 at 6:37am
scriptHelper.shapeFromId("RoundRect");
Also here is a reference for the ScriptHelper class, it might help in other situations too:
http://www.mindfusion.eu/onlinehelp/jdiagram/index.htm?T_com_mindfusion_diagramm...
hans
Reply #2 - Apr 17th, 2012 at 9:57pm
I'll look better next time. Smiley
I did used that helpfile but was looking at the wrong place (shapelist-members)
Reply #3 - Apr 18th, 2012 at 6:11am
If you were programming in Java, you would use the static Shape.fromId method actually. But since static methods and constructors are not accessible from JavaScript (for classes that are not on the system class_path), we have to add equivalent methods to ScriptHelper.
