Normal Topic setEnabledHandles and LayeredLayout @JavaApplet (Read 4481 times)
henry k
Apr 19th, 2012 at 7:48am
Is it possible to set multiple handles options. As option "All" is too much and I haven't found a way to customize these options. In my case this would be simpler if from "All" -option I could disable rotate option.
Also I would like to know how to use Layouts on client-side in JavaApplet mode (if it's possible?). As {MindFusion.Graphs} return [null] and as also {MindFusion.Drawing}... what I'm missing here...?
Br. Henry
Re: setEnabledHandles and LayeredLayout @JavaApplet
Reply #1 - Apr 19th, 2012 at 9:53am
The bit mask for disabled rotation handle should look like "AdjustmentHandles.All & ~AdjustmentHandles.Rotate". Or you can enable only individual handles by setting EnabledHandles to a value such as "AdjustmentHandles.ResizeTopLeft | AdjustmentHandles.Move".
You cannot instantiate Java classes from JavaScript if they are not on the system's class_path, so there are various create* methods exposed via the ScriptHelper class to let you create layout objects:
var applet = <%= diagramView.AppletElement %>;
var treeLayout = applet.getScriptHelper().createTreeLayout();
henry k
Reply #2 - Apr 19th, 2012 at 12:02pm
Thank you, both answers were helpful. Though I'm using LayeredLayout...
#1(case): I used the first option.. ( "AdjustmentHandles.All & ~AdjustmentHandles.Rotate" )
I encountered case of problem when setting orientation to this layout.
Code (Javascript)
var layout = scriptHelper.createLayeredLayout();
layout.setNodeDistance(60);
layout.setLayerDistance(30);
layout.setOrientation(1);  // I was unable to find correct property value to set, but I figured out that default(horizontal) is 0[zero] and vertical is 1[one]..
Reply #3 - Apr 19th, 2012 at 5:23pm
You can use ScriptHelper for finding the constants used as values of various properties:
layout.setOrientation(scriptHelper.getConstant(
    "com.mindfusion.diagramming.jlayout.Orientation", "Horizontal"));
henry k
Reply #4 - Apr 20th, 2012 at 5:24am
wow, how didn't I find this... this was really helpful!
Thank you and br. Henry
