Normal Topic Arranging shapeNode(s) in containerNode(s) (Read 7071 times)
henry k
Apr 20th, 2012 at 11:03am
I'm currently attempting to arrange diagram nodes (JavaApplet) with javascript. I'm able to arrange the first level of layers but not any forward. I.E if I have a containerNode and within it shapeNode(s) and call a fucntion that arranges diagram (all the nodes). All other nodes in diagram are arranged except the ones inside the container node.
So what do I need to do to fix this... I've fixed it on server-side-sample, but in client-side: once again, I'm lost...
(a sample code, perhaps; no need for full code-sample, but the function itself)
Br. Henry
Re: Arranging shapeNode(s) in containerNode(s)
Reply #1 - Apr 20th, 2012 at 2:35pm
What exactly are you doing on the server side that you need to do from client code too?
henry k
Reply #2 - Apr 23rd, 2012 at 7:09am
This may sound stupid, but I have reason for it (too difficult and long to explain). I'm currently keeping 2 separate "dataSet" of diagram. One on client-side and one on server-side.
I may have been wrong to even mention of the server-side functioning... (may get people confused).
But currently I'm having problems of arranging nodes inside containers on client-side with JavaApplet as ClientSideMode.
a) nodes gets to top of the caption "field"
b) if container is placed on diagram; lets say x= 200 & y=200; after arranging containers are moved to (x=20 & y=20) but nodes in this container are not: they stay in place where they were before...
I saw once a similar issue on one of the mindfusion users but I couldn't find the case thus the answer to my question.
Br. Henry
Reply #3 - Apr 23rd, 2012 at 10:20am
You might check the code from the following threads:
http://mindfusion.eu/Forum/YaBB.pl?num=1286496355/1#1
http://mindfusion.eu/Forum/YaBB.pl?num=1330644188/1#1
One problem I can see if you need to run it from the client side is that you won't be able to directly create a DiagramItemCollection from JavaScript (because it's not on the class_path as we discussed before and there's no method in ScriptHelper to create an instance). For now you can call diagram.getItems().clone() to get a new instance and then clear() it.
henry k
Reply #4 - Apr 24th, 2012 at 6:11am
That is problem to me indeed, but now I'm currently developing a workaround...
Thought this has come to a problem also.
Question: when I save diagramView to string does it include the "diagram" from in it?
Test result: as I tested just few minutes ago, I realized that if I save diagramView it doesn't include the "diagram" from it. For example (I set Font: Verdana, 25pt) and when I save diagramView the font is (Verdana, 8.257321...) and all other stuff like handles are also messed up.
Conclusion: It's required to save both, the diagramView and the "diagram" -itself.
Simple explain: You have a wall and you have a picture/paint... if you save the wall, you wont save the picture. If you save picture you wont save the wall. You need to save them separately.
Short question: Is the description above correct?
Br. Henry
Reply #5 - Apr 24th, 2012 at 7:51am
DiagramView.SaveTo* methods save the DiagramView.Diagram content too. Are you sure it's the same diagram you are looking at the client side (considering your earlier Diagram content in Session scenario)?
henry k
Reply #6 - Apr 24th, 2012 at 9:12am
Yes. I compared Base64 string together and before modifications (or the load) they were same, but after the load I noticed a difference and the diagramView content was same but its "diagram" -part settings was default or something really different..
I handled the save scenarios separately (sounds quite stupid, but it works now...) to 2 different Session object-strings.
Though I found out also that when a object (for example: ShapeNode) is modified from server-side its inherited properties will be overwritten... by this I mean that the default settings that you have set on Init scenario and/or in the ASPx control properties... will be overwritten.
--> In this case then the previous case shall be overwritten by this scenario.. (which would make sense)
Br. Henry
Reply #7 - Apr 24th, 2012 at 10:09am
Apart from the different saved strings, were there any visual differences in the diagram? When the applet and the server exchange diagrams, some values might be converted to a different unit (e.g. there's no Unit property in java.awt.Font, so font sizes get converted to the diagram's unit) and this will lead to different string representations.
henry k
Reply #8 - Apr 24th, 2012 at 11:09am
Stoyo wrote on Apr 24th, 2012 at 10:09am:
- No.
- True
In case of font I made a workaround with setting a static font variable in both case...
« Last Edit: Apr 27th, 2012 at 12:41pm by henry k »
