Quote:1. During startup, if I add some nodes to the container node and then set the Folded=False, the container node do not appear Folded.
Shouldn't you set Folded=true to make it folded?
Quote:2. On node double click when Folded property is toggled then it do not raise ContainerFolded or ContainerUnfolded Do we need to call them explicitly?
Yes, these events are raised only if the user folds/unfolds interactively. You'll have to call some method both from the event handlers and after folding programmatically in order to process both cases.
Quote:3. How can the shape of Container Node be templated in Folded State.
You'll have to override ContainerNode.Draw to change the container's shape.
Quote:4. Can we zoom nodes in a particular rectangle area only?
You can't zoom only a part of the diagram,. Perhaps you could show an Overview control over the part you need zoomed, and then set ScaleFactor larger than 100 to zoom in and call Overview.ScrollTo to show the diagram region you need.
