Normal Topic Styling a diagram link (Read 4505 times)
PetrOs
May 7th, 2012 at 9:50am
I have a following problem:
I have a diagram with links, which are running horizontally. I need to style them so, that the label has a text color and a coloured background, and the link itself needs to be styled in line thickness, dashed or not, and color. How do I do this? I managed to only get the text color so far, but not the background or link style, and it is a critical requirement for me...
Re: Styling a diagram link
Reply #1 - May 7th, 2012 at 2:20pm
At this time link labels have a background color set only if link.TextStyle is set to OverLongestSegment. You can style links by setting their Stroke, StrokeThickness and StrokeDashStyle properties.
Gravity
Reply #2 - Oct 4th, 2016 at 11:37am
Stoyo wrote on May 7th, 2012 at 2:20pm:
And how do you set one? I find no such property as Stroke or StrokeThickness in DiagramLink
Reply #3 - Oct 4th, 2016 at 1:25pm
In WPF version of the diagram these properties are derived from the base FrameworkElement class. In the ASP.NET version you are using, you must set the Pen property instead.
Gravity
Reply #4 - Oct 4th, 2016 at 2:01pm
Slavcho wrote on Oct 4th, 2016 at 1:25pm:
Damn you are good.
