Normal Topic can I get the DiagramView which is attached with a Diagram? (Read 1360 times)
GoldyWang
May 10th, 2012 at 7:59am
Since the control is based on Document/View architecture, can I know how many DiagramViews are attached with a Diagram.
   Just like:
DiagramViewCollections views = diagram.Views;
by the way, are there some suggestion when custom a Diagram class?
Re: can I get the DiagramView which is attached with a Diagram?
Reply #1 - May 10th, 2012 at 8:25am
The Diagram doesn't keep track of its views nor knows anything about the DiagramView class. You can use a dictionary<Diagram, DiagramView> if you need to store this information.
GoldyWang
Reply #2 - May 10th, 2012 at 8:47am
I think if the instance of class Diagram can navigate to the views it attached, then the biz logical can easily be packed in a customized Diagram derived class.
