Normal Topic diagramView size (Read 4243 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
diagramView size
May 10th, 2012 at 9:59am
Dear all.
          i want to re size the diagram view as per the screen size. kindly help.
by
Madhan
if you want something then go and grab it
GoldyWang
Re: diagramView size
Reply #1 - May 10th, 2012 at 10:38am
I do not exactly catch what you want, but i think the DiagramView is a WinForm Control, you can resize it as normal winform control can.
you can:
diagramView.Size = new Size(1024,768); // to set fix size
or:
diagramView.Dock = DockStyle.Fill; // to auto-size
Reply #2 - May 10th, 2012 at 12:01pm
In addition to what GoldyWang said, you can find the screen size by calling SystemInformation.PrimaryMonitorSize. Apart from the DiagramView size, you'll probably also have to set diagram.Bounds. Since diagram.Bounds is measured in millimeters by default, you'll have to call DiagramView.ClientToDoc to convert the screen size to millimeters, or otherwise change MeasureUnit to Pixel.
« Last Edit: May 10th, 2012 at 1:15pm by Stoyo »
madhan1
FROM EVERY ONE ..
Reply #3 - May 10th, 2012 at 3:55pm
Quote Modify Remove
hi,
  diagramView.Size = new Size(1024,768);  is not working for me. and diagramView.Dock = DockStyle.Fill;  is filling all the place.
i need to adjust the with
i used the following code also
  diagramView.Width = 1500;
but not working
Reply #4 - May 10th, 2012 at 4:24pm
If you mean you need the view to fill all available space on the form, setting DockStyle.Fill should do that. It won't cover the other controls on your form if you dock them too - set their Dock property respectively to Top/Left/Bottom for the toolbar, listbox and whatever the white control below the diagram view is.
madhan1
FROM EVERY ONE ..
Reply #5 - May 10th, 2012 at 4:44pm
ya,
i already set the Dock setting as bottom for that control..
if i use the dockstyle.fill then i can not see the horizontal scroll bar !!
Reply #6 - May 11th, 2012 at 5:44am
The scrollbar range depends on the diagram size, so this means the view is larger than diagram.Bounds. Assign a larger rectangle to Bounds if you need the scrollbar to be initially visible.
madhan1
FROM EVERY ONE ..
Reply #7 - May 11th, 2012 at 6:02am
hi stoyo,
      i think i have not explain my requirement. i need to extend the with of the diagramview as per the screen size. kindly help
madhan1
FROM EVERY ONE ..
Reply #8 - May 11th, 2012 at 7:01am
sorry i find the issue..
i have set the diagram with in two places.... so it did n't get reflected..
thanks  Roll Eyes
