Normal Topic Drag from FlowChartX to another component (Read 3957 times)
baron
May 10th, 2012 at 3:19pm
I've been trying to find a way to drag from FlowChartX into another component with custom data for several hours now without success.
The goal is to be able to drag a Box into another VB6 ActiveX component in another window, and to be able to extract custom data specific to this Box from this drag&drop action.
Thanks in advance for any pointers - no need for full code, just a list of steps I need to take would help...
Re: Drag from FlowChartX to another component
Reply #1 - May 11th, 2012 at 6:44am
This seems to work -
Private Sub fcx_MouseDown(ByVal button As FLOWCHARTLibCtl.EMouseButton, ByVal keys As Integer, ByVal docX As Long, ByVal docY As Long)
    If Not keys = vbShiftMask Then Exit Sub
    Dim b As box
    Set b = fcx.GetBoxAt(docX, docY)
    If Not b Is Nothing Then
        Dim dataObj As MSForms.DataObject
        Set dataObj = New MSForms.DataObject
        dataObj.SetText b.UserString, vbCFText
        dataObj.StartDrag
    End If
End Sub
baron
Reply #2 - May 13th, 2012 at 9:02am
We can't use MSForms. It isn't redistributable and may not exist on the target computer.
baron
Reply #3 - May 13th, 2012 at 1:26pm
OK in case anyone is interested, I solved this as follows:
I detected a mousemove with the button pressed on the flowchart control, saved the current box info into a variable during this mousemove event, then initiated an OLEDrag on the parent control containing the chart, and handled the OLEStartDrag event on the parent control.
If anyone has a better idea or thinks this approach may have problems, please let me know.
Thanks for your help.
