Normal Topic Keep shape's height unchange, or keep shape's width/height const ? (Read 2856 times)
GoldyWang
May 23rd, 2012 at 8:18am
I want shapeNode, keeping it's height or width unchanged, when resizing them interactively.
and other shapeNode, keeping them the width/height const,
how can i do it?
as the images shows in attachment.
(they are sticks, actually it is the petriNet transition notation)
Re: Keep shape's height unchange, or keep shape's width/height const ?
Reply #1 - May 23rd, 2012 at 9:34am
You could set respectively only the left/right, top/bottom, or move flags in node.EnabledHandles, or perhaps try setting MinHeight=MaxHeight and/or MinWidth=MaxWidth in node.Constraints.
GoldyWang
Reply #2 - May 23rd, 2012 at 10:23am
can we response some resizing event, to keep the width/height scale const ?
such as width/height =0.5,  so as keep the bound similar scale ?
Reply #3 - May 23rd, 2012 at 12:07pm
You can do that by setting node.Constraints.KeepRatio.
GoldyWang
Reply #4 - Jun 4th, 2012 at 2:33am
I not got the ture result till now, wu...
I want the shapeNode, be like a stick, the stick's width is const, and the stick and be extent longer, and can be shorten...
and the stick can be rotated..
Reply #5 - Jun 4th, 2012 at 6:49am
This disables adjustment handles that can change the node's width, so only vertical resize, move and rotate handles will work:
ShapeNode stick = diagram.Factory.CreateShapeNode(0, 0, 10, 60);
stick.EnabledHandles =
	AdjustmentHandles.All &
	~AdjustmentHandles.LeftHandles &
	~AdjustmentHandles.RightHandles;
