Normal Topic can dynamically add/remove anchors? (Read 1194 times)
GoldyWang
May 23rd, 2012 at 8:31am
i want dynamically or interactively add anchors on shapeNode, as the attachment show,
can we?
is there out-of-box solution ?
Re: can dynamically add/remove anchors?
Reply #1 - May 23rd, 2012 at 1:14pm
You should be able to add a new AnchorPoint to AnchorPattern.Points at any time.
If you simply need to arrange links at equal distances along node sides, you can do that without using anchor points; just set the links' end point positions from LinkCreated / LinkModified handlers. The DistributeLinks method here shows how to do that:
http://mindfusion.eu/Forum/YaBB.pl?num=1302946461/1#1
