Normal Topic How to align to anchorpoint? (Read 2412 times)
ncepu
Jun 7th, 2012 at 2:43am
How can I automatically make one ShapeNode align to the anchorPoint of another ShapeNode.Like the attanchment file.The ShapeNode which has the anchorpoints can resize in Horizontal.
Re: How to align to anchorpoint?
Reply #1 - Jun 7th, 2012 at 7:49am
You could align the dependent nodes from the NodeModified / NodeModifying events raised for the node containing anchor points. You can find the diagram location of an anchor point like this:
float x = node.Bounds.X + node.Bounds.Width * ap.X / 100;
ncepu
Reply #2 - Jun 7th, 2012 at 12:48pm
Because there twenty anchorpoint.How to get the anchorpoint which one shapenode connected to when I drawing a link between the two nodes.
Reply #3 - Jun 7th, 2012 at 5:41pm
You can find it form the link's OriginAnchor and DestinationAnchor properties, which specify index within the AnchorPattern.Points collection.
ncepu
Reply #4 - Jun 8th, 2012 at 2:31am
I make it,thanks.I have some other problem yet.
When two nodes is very close,how to select the link between the two nodes.I guess it's the problem of the defining of my shapenode,I don't know how to solve it.
Thanks in advance.
Reply #5 - Jun 8th, 2012 at 7:15am
If the link is over these nodes, setting HitTestPriority to ZOrder should let you select it.
