Normal Topic ControlNode (Read 1120 times)
rnpayet
ControlNode
Jun 10th, 2012 at 10:57am
Hi
I am having issues with maintain the bounds size of the ControlNode when the hosted control changed
any ideas?
Ryan
Re: ControlNode
Reply #1 - Jun 11th, 2012 at 8:14am
When you set ControlNode.Control, the node assigns its Bounds size converted to pixels to the Size property of hosted controls. It seems your control ignores the assigned size, so you'll probably have to set node.Bounds to reflect the control's size. Use the DiagramView.ClientToDoc(Rectangle) method to find the node's size that will fit the control.
