Normal Topic Will source compile for Mono .NET (Mac target)? (Read 1368 times)
Jeff Lindborg
Jun 11th, 2012 at 6:33pm
Sorry if this has been covered before - searched a bit for "mono" and didn't get any hits.
Just curious if anyone has tried compiling the source for the diagraming tool in Mono for use on Mac tool?  Is the source all straight .NET code itself or is there any platform specific items in there that would trip it up?
thanks...
Re: Will source compile for Mono .NET (Mac target)?
Reply #1 - Jun 11th, 2012 at 6:47pm
Last time we tried, a couple of years ago, it compiled but threw a "member not implemented" exception at runtime when trying to set System.Drawing.Graphics.PageUnit. The control uses it to implement the diagram's MeasureUnit property. This could probably be replaced with a ScaleTransform, but we haven't tried it and don't know if there won't be problems with other members.
If you haven't already started developing your tool in Mono/WinForms, you might consider Silverlight - our Silverlight control works fine on Mac and you can also use it for desktop (out-of-browser) applications.
