Hot Topic (More than 10 Replies) send event from node not work (Read 6943 times)
PDM.
Senior Member
Jun 12th, 2012 at 8:47am
Hello
I create a node in this way:
          var newobject = new customnode();
          var node = new DiagramNodeAdapter(form, newobject);
           node.MouseLeftButtonDown += new MouseButtonEventHandler(mymousevent);
           node.SizeSyncMode = SizeSyncMode.SetSize;
           node.Bounds = new Rect(e.MousePosition, new Size(100, 100));
           form.Nodes.Add(node);
           node.HandlesStyle = HandlesStyle.Custom;
           node.Selected = true;
Then on the for i have something like:
    private void mymousevent(object sender, MouseButtonEventArgs e)
   //my coder to execute
is not fired !
Some idea why?
Cheesy
Re: send event from node not work
Reply #1 - Jun 12th, 2012 at 8:57am
Try setting node.MouseInputMode = HandledByControl, or instead of MouseLeftButtonDown handle the PreviewMouseLeftButtonDown event.
PDM.
Senior Member
Reply #2 - Jun 12th, 2012 at 9:11am
I alreay try node.PreviewMouseLeftButtonDown += new MouseButtonEventHandler etc etc
Not work!
node.MouseInputMode = HandledByControl,  ?
That o exists : (
PDM.
Senior Member
Reply #3 - Jun 12th, 2012 at 9:12am
You make reference to  node.MouseInputMode = MouseInputMode.HandledByHostedControl;
I asume yes, testing now!  : )
PDM.
Senior Member
Reply #4 - Jun 12th, 2012 at 9:15am
Using node.MouseInputMode = MouseInputMode.HandledByHostedControl;
No fix the problem, and also no is usefull due after that cant resize node using the handlers Sad
« Last Edit: Jun 12th, 2012 at 10:34am by PDM. »
Reply #5 - Jun 12th, 2012 at 1:05pm
You shouldn't attach a handler to the adapter node, but to the hosted control.
PDM.
Senior Member
Reply #6 - Jun 12th, 2012 at 2:04pm
Sorry, not understand, som example please.
Anyway no any of this solution work, event never fired.
Some solution please?
THK!
Wink
« Last Edit: Jun 12th, 2012 at 3:42pm by PDM. »
Reply #7 - Jun 12th, 2012 at 4:46pm
After this code
instead of
set
newobject.MouseLeftButtonDown += new MouseButtonEventHandler(mymousevent);
I.e. the event will be raised by the hosted control, not by the DiagramNodeAdapter.
PDM.
Senior Member
Reply #8 - Jun 12th, 2012 at 4:58pm
Sorry but that not work is the first thing i test before post here  in the forum  Sad
PDM.
Senior Member
Reply #9 - Jun 12th, 2012 at 5:04pm
Also tested with PreviewMouseLeftButtonDown
Reply #10 - Jun 12th, 2012 at 6:54pm
Adding the code below to the FormEditor example shows the debug output for all the types of controls there. If that doesn't work for your customnode control, I suppose it simply never raises the event. You could check if there is some OnPreviewMouseLeftButtonDown override that does not call base - that would prevent the event from being raised.
private void form_NodeCreated(object sender, NodeEventArgs e)
	var adapter = (DiagramNodeAdapter)e.Node;
	adapter.Control.PreviewMouseLeftButtonDown += OnCtrlMouseLeftButtonDown;
	adapter.MouseInputMode = MouseInputMode.HandledByHostedControl;
void OnCtrlMouseLeftButtonDown(object sender, MouseButtonEventArgs e)
	Debug.WriteLine("mouse down");
« Last Edit: Jun 13th, 2012 at 6:39am by Stoyo »
PDM.
Senior Member
Reply #11 - Jun 14th, 2012 at 5:29am
Thankyou stoyo, i debuged now and see why event no is fired.
No is fixable.
The question, now is, how can send event from inside of custom node to for have fire some event live in form code?
You know some way to do that?
If yes, can tellme how?
Example:
How can i have this event inside a custom node and make form listen to this event:
this.PreviewMouseLeftButtonDown += new MouseButtonEventHandler(mousevent);
Basically i wnat send event from inside of node to code is located in the form.
If pssible ia apreciate showme some exmaple.
Thankyou
Reply #12 - Jun 14th, 2012 at 10:16am
You could try the following to raise the standard PreviewMouseLeftButtonDown event at any time, or otherwise define and raise your custom event using the usual .NET event pattern.
base.OnPreviewMouseLeftButtonDown(
     new MouseButtonEventArgs(Mouse.PrimaryDevice, DateTime.Now.Millisecond, MouseButton.Left));
