Normal Topic "LC.exe" exited with code -1 (Read 5537 times)
AGNTxXx
Jun 15th, 2012 at 8:40am
Do not compile the project. Just add the item diagramView and compile error: "LC.exe" exited with code -1. The package set is only today. How do I fix it? Thank you!
Projects that are located in the samples, normal run.
Re: "LC.exe" exited with code -1
Reply #1 - Jun 15th, 2012 at 8:57am
If you have recently moved from one version of the control to a different build, say trial to licensed or .NET 2 to .NET 4, edit the project's licenses.licx file and set PublicKeyToken=null on the DiagramView line. That should let LC.exe work with any version of the control's assemblies.
AGNTxXx
Reply #2 - Jun 15th, 2012 at 9:13am
Where to find the file licenses.licx?
By the way, classmate threw his library and works with them well!
It turns out that when you install something it was not so.
I have Windows 7. And once stood dot Net 4.0
Reply #3 - Jun 15th, 2012 at 9:41am
You can find licenses.licx in your project's folder. It should also be accessible from the VS solution explorer -> Properties branch; enable the "show all files" option to see it if it's a VB.NET project.
AGNTxXx
Reply #4 - Jun 15th, 2012 at 10:09am
File found, but it did not help!
All the same, the same mistake!
Reply #5 - Jun 15th, 2012 at 11:56am
What's the complete error message shown by LC?
