Normal Topic diagramView_MouseWheel event (Read 2451 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Jun 16th, 2012 at 5:10am
Dear team,
            i want to create a zoom effect in diagramview. but i didn't find mousewheel property in diagramview control. kindly help
if you want something then go and grab it
jf2020
I love FlowChart!
Re: diagramView_MouseWheel event
Reply #1 - Jun 16th, 2012 at 11:18am
The MouseWheel event definitely exists! Make sure that you serach for it on the diagramView and not the diagram
Code (C++)
        /// <summary>
        /// Called when the mouse wheel is used over a diagram.
        /// Default behavior is to zoom in or out of the diagram.
        /// The zooming is to the center of the visible screen.
        /// </summary>
        /// <param name="sender">Not used</param>
        /// <param name="e">Information about the mouse wheel event</param>
        private void diagramView_MouseWheel(object sender, MouseEventArgs e)
            if (e.Delta > 0)
                ZoomToCenter(diagramView.ZoomFactor + 10);
            else if (e.Delta < 0)
                ZoomToCenter(diagramView.ZoomFactor - 10);
madhan1
FROM EVERY ONE ..
Reply #2 - Jun 18th, 2012 at 6:26am
Thaks jf.
         but i am searching in diagramview control only. i have attached the screen shot  FYR
Reply #3 - Jun 18th, 2012 at 7:32am
MouseWheel is marked with a Browsable(false) attribute in the base Control class, so it's no listed in the Properties window. You can still attach a handler from the code behind:
diagramView.MouseWheel += diagramView_MouseWheel;
madhan1
FROM EVERY ONE ..
Reply #4 - Jun 18th, 2012 at 9:09am
Cheesy thanks stoyan
