Normal Topic insert a custom table (Read 4725 times)
Joe
Jun 21st, 2012 at 3:36am
How to do to insert a custom table on the diagram and set its properties? Example:PowerPoint
Re: insert a custom table
Reply #1 - Jun 21st, 2012 at 6:55am
You could use a TableNode:
var table = diagram.Factory.CreateTableNode(rect, cols, rows);
table.Caption = "my table";
table[0, 0].Text = "my first cell";
Alternatively, add an instance of your favorite grid control via DiagramNodeAdapter.
Joe
Reply #2 - Jun 21st, 2012 at 7:30am
But it can not be edited.
Reply #3 - Jun 21st, 2012 at 7:42am
If you set AllowInplaceEdit to true, you can enter edit mode by double clicking a cell. You could also call BeginEdit() from a CellClicked handler to start edit mode after a single-click, or enter it automatically after creating the table.
Joe
Reply #4 - Jun 21st, 2012 at 8:03am
I see ,thank y 。But how to hide the table header。
Reply #5 - Jun 21st, 2012 at 8:07am
Set CaptionHeight to 0.
Joe
Reply #6 - Jun 21st, 2012 at 8:15am
When I drag table sizeForm only length adaptive, not highly also adaptive?
Reply #7 - Jun 21st, 2012 at 8:40am
You can resize rows from the NodeModified handler if they should divide the table's height between them.
void diagram_NodeModified(object sender, NodeEventArgs e)
	TableNode table = e.Node as TableNode;
	if (table != null)
		double rowHeight = (table.Bounds.Height - table.CaptionHeight) / table.RowCount;
		foreach (TableNode.Row row in table.Rows)
			row.Height = rowHeight;
Joe
Reply #8 - Jun 25th, 2012 at 1:00am
I like what you said to set up, but after drawing second lines form frame line is not, such as maps, and cell cannot support the tensile change width, height, And so on
