Normal Topic JSON Serialization (Read 3494 times)
Bubba Ho-tep
JSON Serialization
Jun 25th, 2012 at 9:10pm
Hello, I'm testing out the JS library, and after running through the Tutorials, I realized that I couldn't see how to dump the diagrams back into JSON.
Is there a method that basically returns a JSON object with all the nodes and links (which could then be used to reconstruct the diagram at a later time)?
Thanks!
Re: JSON Serialization
Reply #1 - Jun 26th, 2012 at 8:16am
The Diagram class has built-in string toJson() and fromJson(string) methods, used for the implementation of Canvas mode in our ASP.NET control. Their output might be a bit heavy-weight though; if you prefer JSON objects in a lighter format similar to the one used in tutorial 1, it is easy to generate them like this:
function toJsonString(diagram)
    var graph = { nodes:[], links: [] };
    var nodeCounter = 0;
    diagram.nodes.forEach(function (node)
        node.jsonId = nodeCounter;
        graph.nodes.push({
    diagram.links.forEach(function (link)
        graph.links.push({
            origin: link.getOrigin().jsonId,
            target: link.getDestination().jsonId
    return Sys.Serialization.JavaScriptSerializer.serialize(graph);
Bubba Ho-tep
Reply #2 - Jun 27th, 2012 at 4:39pm
Awesome, that's exactly what I needed.
Thanks!
