Normal Topic ControlNode dynamic drawing problem? (Read 2291 times)
Taivan
Jun 28th, 2012 at 7:00am
I have Diagram and ControlNode. ControlNodes drawing runtime. My problem:
For example :
One ControlNode create first time. it is base node of all node.
Right click the ControlNode show Popupmenu.
Popmenu items : 1.Left, 2.Right, 3.Up, 4.Down.
If i click 1.Left it create node left side on the base node. And click again 1.Left
then create next node on left side. But new created nodes are matching first left
side node.
How i draw custom node run time in nice queue?
See picture?
Re: ControlNode dynamic drawing problem?
Reply #1 - Jun 28th, 2012 at 10:03am
Creating a node to the left of another node should look like this:
ControlNode baseNode = ...;
double dist = 30;
var rect = baseNode.Bounds;
rect.X -= rect.Width + dist;
var newNode = new ControlNode();
newNode.Bounds = rect;
diagram.Nodes.Add(newNode);
Replace the rect.X assignment with the following for the other cases:
// right
rect.X += rect.Width + dist;
// up
rect.Y -= rect.Height + dist;
// down
rect.Y += rect.Height + dist;
