Normal Topic Loosing DiagramLink.OriginAnchor and DiagramLink.DestinationAnchor after SendToBack (Read 2361 times)
Christoph_F
Jun 29th, 2012 at 9:33am
for some reason the connected DiagramLinks which are connected to a DiagramNode loose the information of the OriginAnchor and DestinationAnchor after the DiagramNode was sent to back.
I get the links on the DiagramNode using GetAllLinks(). And the DiagramLinks are added in code:
var diagramLink = new DiagramLink(diagram)
                                          Origin = originDiagramNode,
                                          OriginAnchor = originAnchorIndex,
                                          Destination = destinationDiagramNode,
                                          DestinationAnchor = destinationAnchorIndex,
                                          CascadeOrientation = Orientation.Auto,
                                          CustomDraw = CustomDraw.Full,
                                          Shape = LinkShape.Cascading,
                                          Dynamic = false,
                                          AutoRoute = true,
                                          StrokeThickness = 10.0,
                                          HeadPen = new Pen(Brushes.Black, 10.0),
                                          Stroke = Brushes.Black,
                                          HandlesStyle = HandlesStyle.SquareHandles,
                                          HeadShape = ArrowHeads.Arrow,
                                          ClipToBounds = false
diagram.Links.Add(diagramLink);
After adding the link the OriginAnchor and the DestinationAnchor are correct.
Anyone ancounter this behavior before?
thanks,
Christoph
Re: Loosing DiagramLink.OriginAnchor and DiagramLink.DestinationAnchor after SendToBack
Reply #1 - Jun 29th, 2012 at 10:09am
What does "send to back" involve in your application? Links could detach from anchor points when they are modified by user or auto-routed. Try setting RoutingOptions.Anchoring to Keep, SnapToAnchor to CreateOrModify and/or AllowUnanchoredLinks to false to see if any of these options helps in your case.
Christoph_F
Reply #2 - Jun 29th, 2012 at 10:22am
I tried these options but that did not help...
Also it is not just "SendToBack" but also other interactions (adding another element etc.) brings the same strange behavior but not all the time.
So I am stuck. At the moment I manually figure out the correct anchor point by finding the nearest (based on the start/end point of the link ControlPoints) but it would be a smarter way if I could use the Origin/DestinationAnchor directly.
Reply #3 - Jun 29th, 2012 at 12:04pm
Could you attach here a small test project showing what's wrong with anchor points?
