Normal Topic Create Settings Panel for Shape (Read 2318 times)
SL_developer
coding rocks
Jul 5th, 2012 at 6:24am
Hi
Please check the attachment for Images, I need to develope something like this
with Mind Fusion shape control.
Is it possible?
Images.rar (Attachment deleted)
Re: Create Settings Panel for Shape
Reply #1 - Jul 5th, 2012 at 9:06am
You can implement the gear icon either as a separate node attached to the main node, or show it as part of the node's template. If it's an attached node, handle NodeClicked event and show the setting panel for e.Node.MasterNode. If you change the template, you will have to implement your own hit-testing in NodeClicked to determine if the gear has been clicked.
As for showing the panel, if it should be a part of the diagram and follow the node whose information it displays, use an attached CotnrolNode that hosts the panel control. Otherwise, just show it as a popup dialog.
