Normal Topic Deletion of multiple nodes with a single confirmation message (Read 1688 times)
kausar
Jul 5th, 2012 at 9:06am
When i delete multiple nodes i get confirmation message for each node instead i need to get a single messagebox and all the nodes should be deleted on ok
Re: Deletion of multiple nodes with a single confirmation message
Reply #1 - Jul 5th, 2012 at 9:26am
You could intercept the Delete command instead of showing confirmation dialog in the NodeDeleting handler:
CommandManager.AddPreviewCanExecuteHandler(diagram, CanDelete);
void CanDelete(object sender, CanExecuteRoutedEventArgs e)
	if (e.Command == ApplicationCommands.Delete)
		if (MessageBox.Show("you sure ...?",
			"...", MessageBoxButton.YesNo) == MessageBoxResult.No)
			e.Handled = true;
			e.CanExecute = false;
