Normal Topic display a watermark (Read 2735 times)
bashi003j
display a watermark
Jul 9th, 2012 at 9:46am
I want to display something like a watermark or something like it shows when we set the property
Resource Length Method to ResourceLengthMethod.MinimumFixed.
basicaly 2 colors in the header part or in the item.
is this possible in mindfusion .net planner ?
thankyou.
Re: display a watermark
Reply #1 - Jul 9th, 2012 at 12:26pm
You can do this by using custom drawing. Set Calendar.CustomDraw to ResourceViewItem, then handle the Calendar.Draw event and use the following code in the event handler:
if (e.Element == CustomDrawElements.ResourceViewItem)
	using (Brush watermark = new SolidBrush(Color.FromArgb(100, Color.Black)))
		e.Graphics.FillRectangle(watermark, e.Bounds.X, e.Bounds.Y, Math.Min(e.Bounds.Width, calendar1.ResourceViewSettings.MinResourceLength), e.Bounds.Height);
bashi003j
Reply #2 - Jul 9th, 2012 at 12:46pm
Thanx alot Meppy... thats exactly i was searching for...
Thanx again
