Normal Topic High light the selected node (Read 2960 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Jul 11th, 2012 at 4:18am
Dear stoyan,
             how to high light a selected node
if you want something then go and grab it
Re: High light the selected node
Reply #1 - Jul 11th, 2012 at 6:13am
Change e.Node.Brush from NodeSelected / NodeDeselected events, or draw some kind of highlight from the DrawAdjustmentHandles event handler.
madhan1
FROM EVERY ONE ..
Reply #2 - Jul 11th, 2012 at 10:48am
Dear stoyan,
     i used the following code  in Nodeselected event. but it is not working
SolidBrush myBrush = new SolidBrush(Color.Red);
              e.Node.Brush = myBrush;
Reply #3 - Jul 12th, 2012 at 7:34am
What's not working?
madhan1
FROM EVERY ONE ..
Reply #4 - Jul 12th, 2012 at 7:36am
the node is not changing the color
Reply #5 - Jul 12th, 2012 at 11:28am
If you are using ControlNodes, you will have to change some property of the hosted controls, such as BackColor. There's no way the Brush property to not work for other node types, unless you are custom-drawing them and not using the specified brush.
