Normal Topic Rotation issue (Read 2883 times)
Vangelis Komninos
Rotation issue
Jul 16th, 2012 at 3:14pm
Hello guys!
I have a problem in order to rotate all objects inside a group. Although I have add the FollowMasterRotation=true, the objects seem to become bigger and smaller when I manually rotate the master box. My goal is to rotate everything inside by following the master object's move. Just like a label in a CD disk.
Check my simple code:
    Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
        bx1 = AxFlowChart2.CreateBox(40, 40, 300, 300)
        bx1.Style = FLOWCHARTLib.EBoxStyle.bsShape
        bx1.RotateContents = True
        bx1.RotateText = True
        bx1.LayoutStyle = FLOWCHARTLib.ELayoutStyle.lsCustom
        grp1 = AxFlowChart2.CreateGroup(bx1)
        bx2 = AxFlowChart2.CreateBox(10, 10, 50, 50)
        bx2.Style = FLOWCHARTLib.EBoxStyle.bsShape
        grp1.AttachProportional(bx2, 10, 10, 50, 50)
        bx3 = AxFlowChart2.CreateBox(70, 70, 20, 20)
        bx3.Style = FLOWCHARTLib.EBoxStyle.bsShape
        grp1.AttachProportional(bx3, 70, 70, 20, 30)
        grp1.FollowMasterRotation = True
        bx1.MoveTo(40, 40)
    End Sub
I would appreciate your help
Best Regards
Vangelis Komninos
Re: Rotation issue
Reply #1 - Jul 17th, 2012 at 7:37am
Attached items are not rotated along with the main node at this time. They just follow the position of the attachment point while it moves around. We have recently implemented full rotation support for groups in the WPF version of the control and will port it to other platforms in the next few months:
http://mindfusion.eu/Forum/YaBB.pl?num=1337766957
