Normal Topic How to save my diagram? (Read 8455 times)
Taivan
Jul 17th, 2012 at 8:53am
Hi stoyan.
How to save my diagram items and controls.
What kind of options? (Syntax)?
Please share me thank you Cheesy
Re: How to save my diagram?
Reply #1 - Jul 17th, 2012 at 9:24am
You can use the SaveToXml and LoadFromXml methods of the Diagram class. If you use ControlNodes, you must handle the SerializeControl and DeserializeControl events to implement serialization of hosted controls' properties.
Taivan
Reply #2 - Jul 17th, 2012 at 9:26am
Stoyo wrote on Jul 17th, 2012 at 9:24am:
Do you have any sample? Cheesy
Reply #3 - Jul 17th, 2012 at 10:02am
You can find sample handlers here:
http://www.mindfusion.eu/onlinehelp/diagramlite/index.htm?E_MindFusion_Diagrammi...
Taivan
Reply #4 - Jul 18th, 2012 at 1:27am
Stoyo wrote on Jul 17th, 2012 at 10:02am:
Hi stoyan. Sorry for my bad programming skill. Please see my uploaded project.
I want save my diagram to file is it possible?
thank you. Cheesy
http://www.4shared.com/rar/wtDbUj1d/PrototypeV2.html
Reply #5 - Jul 18th, 2012 at 8:48am
Please attach the test project to your forum post. 4shared require registering an account with them to download and I am not getting their activation email message. Remove any dll and xap files from the archive to make sure it fits into the forum's 250KB limit.
Taivan
Reply #6 - Jul 18th, 2012 at 8:54am
Stoyo wrote on Jul 18th, 2012 at 8:48am:
Okay here is my proj file
PrototypeV2.rar (Attachment deleted)
Reply #7 - Jul 18th, 2012 at 11:11am
Calling diagram.SaveToXml("test.xml") will save the file in the Silverlight's isolated storage. If you want to save a file on the file system, you will have to use a SaveFileDialog:
var saveFileDlg = new SaveFileDialog
	Filter = "XML Files (.xml)|*.xml|All Files|*.*"
if (saveFileDlg.ShowDialog() == true)
	using (var stream = saveFileDlg.OpenFile())
		diagram.SaveToXml(stream);
Otherwise, due to Silverlight security restrictions you can't save directly on the FS by specifying a full file path.
Taivan
Reply #8 - Jul 19th, 2012 at 3:32am
Stoyo wrote on Jul 18th, 2012 at 11:11am:
Thanks i can save my diagram to file. But Load my diagram from file i lost my ControlNodes binding controls. Any suggestions Stoyan? Cheesy
My load Code is here:
var openFileDlg = new OpenFileDialog
                    Filter = "XML Files (.xml)|*.xml"
                if (openFileDlg.ShowDialog() == true)
                    using (var stream = openFileDlg.File.OpenRead())
                        diagram.LoadFromXml(stream);
Reply #9 - Jul 19th, 2012 at 9:05am
You will have to handle SerializeControl and DeserializeControl events to handle serialization of custom controls. The help topic linked above contains some sample event handlers.
