Normal Topic Is there a way to capture right-click on a node in ImageMap mode? (Read 2992 times)
jlj30
Jul 26th, 2012 at 4:22pm
I'd like to implement a contextual menu on the right-click of a node.
Is there any way to accomplish this in ImageMap mode?
Thanks in advance for any suggestions.
Jim
Lyubo
MindFusion team
Re: Is there a way to capture right-click on a node in ImageMap mode?
Reply #1 - Jul 27th, 2012 at 10:08am
Hi Jim,
There is the NodeClicked client event, but unfortunately it is raised only for left-button clicks.
As a workaround you can use the DiagramView CreatingAreaElement server side event, which you could handle to pass a custom attribute to the created node on the client - for example, you could attach a mousedown client event handler. Then handle the event on the client to show a context menu at the cursor.
If you need to suppress the browser's own built-in context menu, handle the body.oncontextmenu event and return false:
Code (HTML)
 <body oncontextmenu="return false;">
You can check out our Menu control from the ASP.NET Pack release: http://www.mindfusion.eu/ui-webforms-pack.html#menu to use as a context menu. Set the orientation to Vertical and place it in a hidden DIV element. With it you can create something like this:
These are some code snippets that can help you to achieve this
void DiagramView1_CreatingAreaElement(object sender, MindFusion.Diagramming.WebForms.CreatingAreaElementEventArgs e)
  // Attach the mousedown event handler
  e.Attributes["onmousedown"] = "return onNodeMouseDown(event)";
Code (HTML)
<!-- Register the MindFusion.UI.Web assembly to use the Menu control -->
<%@ Register Assembly="MindFusion.UI.Web" Namespace="MindFusion.UI.Web" TagPrefix="ui" %>
<!-- omitted code... -->
<!-- Set up the Menu -->
<div id="contextMenuContainer" style="display: none;">
  <!-- The Menu control -->
  <ui:Menu ID="Menu1" runat="server" Orientation="Vertical" Theme="Silver" ItemClickedScript="onMenuItemClick" ShowTrail="true">
    <ui:MenuItem Title="Action 1">
      <ui:MenuItem Title="Sub Action 1.1" />
      <ui:MenuItem IsSeparator="True" />
      <ui:MenuItem Title="Sub Action 1.2"/>
    </ui:MenuItem>
    <ui:MenuItem Title="Action 2" />
  </ui:Menu>
</div>
Code (Javascript)
* Handle the mousedown event to show the menu container
function onNodeMouseDown(e)
  if (e.button == 2 /* for right click */)
    // show the context menu and place it at the mouse cursor
    var ctxmenu = $get('contextMenuContainer');
	if (ctxmenu)
	  // This may be not enough, and some addtional processing
	  // for determining the location to place the element may be required.
	  Sys.UI.DomElement.setLocation(ctxmenu, e.clientX, e.clientY);
	  ctxmenu.style.display = 'block';
* Handle the Menu.ItemClicked client event to respond
* when a user clicks on a MenuItem and then hide the menu again.
function onMenuItemClick(sender, args)
  // Process the clicked item
  // hide the context menu.
  if (ctxmenu)
    ctxmenu.style.display = 'none';
I hope you'll find this helpful.
Lyubo
jlj30
Reply #2 - Jul 27th, 2012 at 12:33pm
Great response.
Thanks for all of the code snippets.
This is more than I was expecting.
I'll try it out.
Jim
