Normal Topic Please come in, maybe this is a bug (Read 2854 times)
CanadaProgrammer
Jul 31st, 2012 at 11:16pm
There 2 buttons, A and B.
The click event of A is to append a ShapeNode to a diagram
The click event of B is call the method ResizeToFitItems of Diagram,
You will find location of the shape is changed. why???
Re: Please come in, maybe this is a bug
Reply #1 - Aug 1st, 2012 at 6:50am
The on-screen location of all nodes might change if the diagram's origin changes and it's no longer in the view's current scroll range, e.g. if the new node is the left-most or top-most in the diagram and you call ResizeToFitItems. If you allow the diagram to only grow this shouldn't happen - instead of calling the Resize method, set diagram.Bounds to the union of current Bounds value and diagram.GetContentBounds().
CanadaProgrammer
Reply #2 - Aug 2nd, 2012 at 12:37am
Looks it can work, but I still have a question. Let's call method GetContentBounds like below:
RectangleF rectContent = this.diagram1.GetContentBounds(false, false);
In my case, the value of rectContent.X is -2, and the value of rectContent.Y is -2. but diagram.Bounds.Location.X is 0, diagram.Bounds.Location.Y is 0. Why can method GetContentBounds return (-2, -2) ?
CanadaProgrammer
Reply #3 - Aug 2nd, 2012 at 12:41am
By the way, the whole node is visible on diagram completely, i mean every point that contained by the node is on client area of diagram and is visible
CanadaProgrammer
Reply #4 - Aug 2nd, 2012 at 2:08am
In my case, I click button A to add a node, then click button B to call then method. do nothing between clicking button A and clicking button B
Reply #5 - Aug 2nd, 2012 at 6:25am
CanadaProgrammer wrote on Aug 2nd, 2012 at 12:37am:
GetContentBounds returns the union of GetRepaintRect() results. GetRepaintRect adds AdjustmentHandlesSize to the node's Bounds so that selection handles are included too in the diagram/repaint area. If you don't wish to include them, just create the union of Bounds of all items.
