Normal Topic sample source code demonstrates zoom in/zoom out in a diagram (Read 1531 times)
Shiju
Aug 2nd, 2012 at 8:50am
Please provide a sample source code which demonstrates zoom in/zoom out functionality in diagram.
Also i want to know how to store this zoom state
thanks,
Shiju
Re: sample source code demonstrates zoom in/zoom out in a diagram
Reply #1 - Aug 2nd, 2012 at 11:17am
You could check the OnMouseWheel handler in the FractalLayout sample project.
ZoomFactor is not saved by SaveToXml. You could use SaveToXml(XmlDocument) and LoadFromXml(XmlDocument) methods to append additional information such as zoom state to the XML document. Or as an easier solution, set diagram.Tag = ZoomFactor before saving and ZoomFactor = (double)diagram.Tag after loading (if you aren't already using Tag for something else).
