Normal Topic How to select a node under transparent image node? (Read 3618 times)
shapi
Aug 3rd, 2012 at 3:46am
There is a node under a node with transparent image. How to select the node without move away the image node?
Re: How to select a node under transparent image node?
Reply #1 - Aug 3rd, 2012 at 7:14am
Set Locked = true for the image node and the diagram will select the node behind it. If you don't wish to lock it, you could change the selection from the NodeClicked event handler if e.Node is the image node.
shapi
Reply #2 - Aug 3rd, 2012 at 9:49am
The NodeClicked event cann't return the position of mouse. I need to check if the position of image I clicked is transparent or not.
Any other solution? What about to override DrawNodesBehavior?
Reply #3 - Aug 3rd, 2012 at 11:15am
When NodeClicked is raised, e.MousePosition gives you the mouse position in diagram coordinates. You can subtract the origin of e.Node.Bounds from it to find the mouse position relative to the node. Then you should be able to find the position of the image pixel from the node-relative point depending on the ImageAlign value you are using. E.g. if ImageAlign is Stretch, the image pixel should be (image.Width * nodePoint.X / node.Bounds.Width, image.Height * nodePoint.Y / node.Bounds.Height).
shapi
Reply #4 - Aug 7th, 2012 at 8:49am
Good.
And how to change the selection of node? When click the transparent part of image, I can unselect it with (e.Node.Selected=false). But how to allow select the node under the transparent image?
Reply #5 - Aug 7th, 2012 at 10:04am
Call GetNodesAt to get a list of all nodes at the specified position. They are sorted in reverse Z order, so the transparent node should be at index 0, and the one below it at index 1. If your application allows stacking many transparent nodes on top of each other, I suppose you could loop over the returned collection until finding a non-transparent node to select.
shapi
Reply #6 - Aug 8th, 2012 at 12:52am
