Normal Topic Really good viewer (Read 4645 times)
AlexB
Really good viewer
Aug 15th, 2012 at 7:55am
First of all I have to say that your XML viewer is the best viewer from the dozen which I tried. At least from freeware list.
Thank you, great work!
Few small points/whishes:
1.      If I define the Viewer as a default for XML files and double clicking on some file, Windows fail to open with error message:
" The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher."
I suppose the problem is that I use Windows 7 64 bit.
2.      Wrap search/Search with F3 and Shift+F3 are really missing
3.      File size problem:  1M -20.5 sec, 2M-86 sec
4.      Refresh of the opened file: manually and when file is changed on disk.
exampleFiles.ZIP (Attachment deleted)
Re: Really good viewer
Reply #1 - Aug 15th, 2012 at 9:57am
Thank you for your feedback. We have discontinued the support for the XML Viewer tool but have plans for a probable rewrite in the future. If we decide to release a new version, we will make sure to include all the useful user requests.
