Normal Topic how to add context menu in the latest diagram lite (Read 4268 times)
bink
Aug 16th, 2012 at 7:50am
We recently upgraded MindFusion.Diagramming.Silverlight to version 2.2.0.27163.  It went well except for the context menu stopped working.
Our current code is :  ContextMenuService.SetContextMenu(diagram, menus);
Could you provide an example of context menu that work with the current version?  We are using silverlight 5 at the moment.
Regards
Bill
Re: how to add context menu in the latest diagram lite
Reply #1 - Aug 16th, 2012 at 12:04pm
The control now handles right clicks internally and that might be preventing the service from showing menus automatically. You can open the menu from Diagram.Clicked or NodeClicked event handlers:
<tkit:ContextMenu Name="contextMenu">
void OnNodeClicked(object sender, NodeEventArgs e)
    if (e.MouseButton == MouseButton.Right)
        contextMenu.IsOpen = true;
bink
Reply #2 - Aug 17th, 2012 at 12:55am
Thanks Stoyan! It solved my problem.
